UKWorkshop Woodworking Forums
Post new topic Reply to topic  [ 60 posts ]  Go to page Previous  1, 2, 3, 4  Next
Author Message
PostPosted: 10 Aug 2017, 16:11
Offline
Valued Contributor
Has thanked: 22 times
Been thanked: 141 times
Either or. If it got to be much more than that, then I'd be thinking of at least taking some from the back side. Which shouldn't be an issue if it has not been modified before, because it should have a scoop in its back that doesn't exist on a parallel iron (and is therefore not needed in an infill plane).
If the iron bedded nicely and adjusted nicely with good even pressure across the lever cap, I'd probably just take it off the front in that small of an amount, but I am better at working the face of irons than most people. Not because of skill, only because of experience and repetition.
 Profile
PostPosted: 11 Aug 2017, 20:12
Offline
Settling In
Has thanked: 2 times
Been thanked: 22 times
Well, you were all right! The tapered iron fits after all and does a great job. Not really expecting it to work, I just hollow ground it and put on a 30 degree bevel, flattened the back a little and...
The plane works really well and takes thin, full width shavings with hardly any further fiddling and no work to the sole at all. I can see why folk get so enthusiastic about infills.
Thanks for all the help guys.
Richard
 Profile
PostPosted: 11 Aug 2017, 20:56
Offline
Prolific Contributor
User avatar
Has thanked: 851 times
Been thanked: 494 times
I'm happy that you're happy - and a decent price too, less than any LV or LN!
BugBear
_________________
...a sharp tongue is the only edge-tool that grows keener by constant use.
-- Washington Irving
 Profile
PostPosted: 11 Aug 2017, 22:12
Offline
Valued Contributor
I guess my chance of getting it off of you has probably dwindled to zero :)
 Profile
PostPosted: 19 Aug 2017, 00:03
Offline
Settling In
:D
Richard
 Profile
PostPosted: 21 Aug 2017, 12:48
Offline
A Regular Member
Has thanked: 131 times
Been thanked: 65 times
No affiliation with this tool auction. http://www.pitchersauctions.com.au/cata ... gust-2017/?
 Profile
PostPosted: 21 Aug 2017, 14:44
Offline
Valued Contributor
richarddownunder wrote:
:D
Richard
Oh, Richard, it just looks terrible. But I'm sure it would fit in my mailbox. :D
 Profile
PostPosted: 22 Aug 2017, 05:08
Offline
Settling In
Wow, they have a lot of stuff there. I wonder how much it goes for?
 Profile
PostPosted: 22 Aug 2017, 05:11
Offline
Settling In
:D
Richard
:lol:
 Profile
PostPosted: 29 Aug 2017, 09:50
Offline
Settling In
Really enjoying using this Preston, the more I look, the more I realise how well made they were. Sorry to say D_W.
A couple of questions though:
1 is this the finish typical of these sorts of forged irons or has it been rusty at some stage? As we established, it aint the original and I cant find one on e-bay (2 1/4 inch)
2 The plane works very nicely and has a great feel to it - no tear out to speak of on sapele but the edge only holds up for a short time. I can get a lot longer out of my Cliftons or Records. So, in practical terms, would I be better to get a new Ray Iles iron to use instad of the Preston tapered iron? Sharpening isn't the problem, I'm fairly proficient at that, but it does take me a minute or two to get it adjusted nicely (maybe due to my lack of practice).
Has anyone on the site substituted an old (tapered) plane iron with a new one and found they hold up better?
Richard
 Profile
PostPosted: 29 Aug 2017, 10:05
Offline
Valued Contributor
User avatar
Has thanked: 620 times
Been thanked: 1180 times
That plane iron certainly looks to me as if it has been rusty and has been cleaned up (nicely) with acid or commercial rust remover. The upper parts of an iron, exposed beyond the shelter of the body, are often the first to succumb to rust when left in a shed. Yours has the tell-tale black specks where rust had started to eat pits into the steel. Acid turns them black, but it's impractical to get the black out of the pits, where abrasives etc won't reach.
I wouldn't worry about it. You might be able to find a new old stock iron, but that could have rust by now, after sixty years or more in storage.
_________________
Andy
 Profile
PostPosted: 29 Aug 2017, 10:35
Offline
Regular Contributor
Has thanked: 1 time
Been thanked: 103 times
You could try grinding the edge back a mm or 2. And sharpen at a higher angle. Up to 35 degrees or so. That helps edge life too.
How do you sharpen, oilstones, or something else? And how does the edge fail, chipping or folding?
 Profile
PostPosted: 29 Aug 2017, 11:26
Offline
Valued Contributor
In my experience, tapered irons are a few clicks softer than parallel irons. Not necessarily true for every single one, but on average.
My preferences are ih sorby, Ward and Mathieson parallel irons, but new are ok. They just look very bad in an old plane. If it's very soft, save it for a wooden plane that does heavier work where that softness won't matter.
 Profile
PostPosted: 29 Aug 2017, 20:24
Offline
Settling In
Thanks for the replies. I think it is just a bit soft and dulls quite quickly - it doesnt chip. I have ground it back a bit and could try the steeper angle - it is 30 degrees at the moment. I use a fine diamond stone then a waterstone..4000 grit I think (and I still use a honing guide!). I noticed this http://www.jimbodetools.com/PRESTON-Thi ... 58121.html It is a bit wide (could grind off 3 mm) but looks a bit worn anyway. I understand that a new iron might look a bit out of place but if it held an edge better, that is the more important thing. The alternative is another non-preston parralel iron - there must be a few about. Could always get a new one and leave it in the rain for a week to look more the part :)
Richard
 Profile
PostPosted: 29 Aug 2017, 22:17
Offline
Valued Contributor
Lots of sorby and others. Ward are tough to get reasonable because people need them to fit in old Norris planes that have lost their original irons.
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 16 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
 Similar topics   Author   Replies   Views   Last post
Boxwood smoother
in Hand Tools
TFrench
3
594
17 Apr 2017, 09:25
Stanley No4 1/2 smoother ONE LEFT
in For Sale
toolsntat
4
1042
19 Nov 2017, 21:23
New Infill plane
in Hand Tools
arnoldmason8
18
920
25 Jul 2017, 23:15
Anyone Used a Wedged Infill Plane?
in Hand Tools
D_W
20
1255
23 May 2017, 13:21
Coffin Infill Question - Spiers
in Hand Tools
D_W
16
685
06 Jun 2017, 17:21
Register UKW
User Tools
UKW Local
Quickly find the nearest tool suppliers & timber merchants in your area
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
UKW Terms & Privacy
