Danish oil finishing on cabinet
Jimmy Rip
New member
14 Sep 2015
Fremantle, WA
Hi guys,
First post, pretty much a newbie.
I've made some bookshelf speaker cabinets out of jarrah (australian hardwood) and would like to finish in danidh oil.
Reading up I understand it is important to keep first coat wet for 20 - 30 minutes. I have already built the cabinets so I'm concerned about how to oil it.
If I stand them up and oil all over initially, the oil on the sides will slide off. Alternatively, if I try to do one side at a time obviously this will spill over the sides and I imagine that will leave an uneven finish.
Hope that makes sense. What do you advise?
Oh yeah, I live in Perth and it's blimmin' hot so oil will dry quickly, although I could go for early morning if that is an issue.
Thanks in advance.
Jim
As a fellow newb. Not sure how much you can rely on this advice but could you try taping the edges to prevent overspill and wiping any as it occurs. One thing I would recommend is to stain on a test piece. If you have any spare aussie hardwood make a small box and test it out.
I think you have been given misleading advice. Afaik there is no necessity of keeping the Danish oil wet for a minimum time. What does matter is that within an hour or so you wipe over with a clean cloth to remove any surplus oil. Probably within half an hour if it's really hot. If you don't do this you can get a surface skin over a sticky mess which won't cure properly.
But if all of the mixture has dried/cured in that time there won't be any surplus to remove.
