Heath Robinson
Hi all.
Apologies for the long post, there's a fair bit to describe.
I've got a 3-wheel inca bandsaw, which is playing silly pippers.
There's been an odd and intermittent vibration and groaning of late, which I traced to a combination of a fairly stiff-to-turn bottom wheel, an old and lumpy drive belt, and secondarily these two causing the collet on the motor belt tensioner to come off, allowing the tensioner to come un-tensioned.
Now, while fixing these, I started with the tensioner and belt, and before I noticed how tight the wheel was, the motor stalled a couple of times.
The last time, it smelled a bit funny, and without the belt on would only run at half speed. Opening up the connection box, I found a wire had shorted, from the smaller capacitor (inside the connector box, maybe 2-1/2" by 1") to a motor terminal, severing the wire.
I soldered this up, put everything back together, and voilà, all runs as it should.
While lightly filing the back edge of the blade, the motor stalled or at least dropped to a slower speed and juddered for a second, before there were two loud pops, and the NVR switch clicked off.
The pops turn out to be the larger capacitor having split it's plastic case, and popped it's self.
I think I did the drive belt tensioner up a bit tight, in an effort to stop the belt bouncing at the bottom, as it seemed to bounce and rumble more than I liked. It's a cheapo one from a local car place, so I've ordered a new Gates notched belt for it.
So, anyone know how to work out what large capacitor I need? There's no markings on the popped one.
Also, anything I should check with the motor to ensure all is happy and healthy?
Thanks in advance
Jake
Thanks in advance
Jake
