Using washing machine motors
Really wish I hadnt looked at this thread, now I want to make a drum sander......damn!! Another project to add to the list of projects! :p
Anyway, the Aldi saws were mentioned and it occured to me that I have one of those saws sitting on a shelf in the shop collecting dust these past few years!
Had a look at the ratings, it says:
Power:
S1 750W
S2 30min 1000W
2950RPM
Then, I pulled it assunder, I've been contemplating chucking it out numerous times but always thought 'but what if I need a small saw for something', but all that ended tonight, its in 100 parts now, so, its either a drum sander or keep the motor and switch and chuck the rest! :)
Would that be adequate for such a drum sander? And, while I'm here, I was just wondering, what is the actual drum made of?
Actually, disregard my last question, it seems the drum can be made up of numerous MDF or plywood rings glued and sandwiched together and then wrapped with self adhesive velcro.......simples! :wink:
A lenght of mild steel tubing, say 5" diameter or so (for a 12" drum) would do the job also I presume? With a rin cut and fitted into either end and perhaps one or two in the middle to support the shaft?
I'm going to make one of these I think, however as I'm very limited for space I'd have to make a bench top one that I can store when not in use. I was thinking of making the frame out of steel, 30mm box section or so and welted/bolting it together. Is there any disadvantage of using steel over timber? Would a timber frame absort some of the vibration etc better than a steel frame? It'll be bolted to a workbench when I'm using it so I cant see it being a problem.
Here's a few links that I found helpful!
http://www.rockslide.org/drum%20sander.html (plenty of WIP pics!)
http://www.areddy.net/wood/tools.html
http://lumberjocks.com/projects/7641 (a really nicely made one!)
I think the link will work. But I don't know exactly how this going to work though. One tip, I am only trusting big companies, as a matter of fact, I have been using my GE washing machine for many years now and no worries at all!
