| Author |
Message |
OPJ Master Cabinetmaker
Joined: 31 Jul 2005 Posts: 5036 Location: North Somerset
| Posted: Mon Mar 01, 2010 9:54 pm Post subject: Storing Sheet Materials |
Hi guys,
If I can get rid of a couple more items of junk then I should have enough room to build a simple storage area for laying sheet materials horizontally (the walls are only 2100mm). This'll be right next to the up-and-over door, just behind my mitre saw station, which is on 100mm castors.
This is currently what I have in mind:
There's about 2500mm (plenty! ) between the end wall and pillar and the length of the "pen" isn't critical (I'll go with the length of my spare OSB sheets). Those studs would be tapered in length; cut from two lengths of 4"x2" and fixed to the wall. I don't want to build it up too tall at the front or it will foul the mitre saw cabinet. Angling them back toward the wall slightly is ideal.
My main priority here is not only to tidy them up but to get them off the damp walls and floor during the winter (I recently had to throw away a good amount of 6mm ply ).
What do you think of this idea?
While I can't afford the space for a fancy fold-up unit that provides you with a cutting-bench, are there any other ideas out there that I could consider? I haven't been able to find much, myself.
Above this, I will eventually fit another wood rack (...in addition to the four-or-five elsewhere...!! )
This is how it was looking a few weeks ago, by the way....
(A couple of tools have moved around or been replaced, since then. Regardless; that large mess in the middle remains there today! )
Thanks for looking,
Olly. _________________ Olly.
My Blog: http://ollypj.wordpress.com/
Flickr Photos
Website: http://opj-furniture.co.uk/ |
| Back to top |
big soft moose Master Cabinetmaker
| Posted: Mon Mar 01, 2010 10:46 pm Post subject: |
so when i come over to collect the variety of dust extraction goodness, we should also do a deal on "offcuts"
there looks to me to be a bookcase and a sewing table lurking in that pile of mess  _________________ money talks, and thats no lie
I heard it once, it said goodbye ! |
| Back to top |
Shultzy Cabinetmaker
Joined: 10 Oct 2006 Posts: 1700 Location: Near Lichfield, Staffordshire
| Posted: Mon Mar 01, 2010 11:25 pm Post subject: |
| Quote: | | If I can get rid of a couple more items of junk then I should have enough room to build a simple storage area for laying sheet materials horizontally |
Olly, I assume you mean the sheets on their sides . The angle between the wall section and the floor section should be 90degs and no piece of wood should rest on the actual wall or it defeats the object of the exercise. _________________ Photo's at http://shultzy.fotopic.net/
Workshop Here
Workbench Here
RouterTable Here |
| Back to top |
wizer Professional Mutterer
Joined: 03 Mar 2005 Posts: 15317 Location: Creating and Fixing C*ckups Nr Dartford, Kent.
| Posted: Tue Mar 02, 2010 12:07 am Post subject: |
Storing ply is a pig. Do you need to keep it in stock? _________________ **UK Workshop Forum Badge? Now taking orders, get one before they run out!**
“Success is not final, failure is not fatal: it is the courage to continue that counts.” |
| Back to top |
| Posted: Tue Mar 02, 2010 10:41 am Post subject: |
Pete, no sewing table but there is an MFC bookcase/shelf-thing. It's been on Freecycle for two-weeks now but no takers. I may have to break it up and use the longer lengths to build this rack/pen as well. Believe me, I do now have plans for all that oak and beech!
Shultzy, you are quite right - laying on their longest edge (no more than 1220mm high)! Are you saying I should angle the base so it's perpendicular to the back or return the back to 90°?
Tom, I seem to spend more time working with sheet materials than any timber at the minute. Even if I need only a small sheet, it's cheaper in the long run to buy a full one and cut it down where necessary. _________________ Olly.
Flickr Photos
| Back to top |
| Posted: Tue Mar 02, 2010 9:56 pm Post subject: |
| OPJ wrote: | | Shultzy, Are you saying I should angle the base so it's perpendicular to the back. |
Yes the angle between the back and base should be 90degs. This makes sure that all sheets press onto each other, keeping them flat. If not the sheets will start to slip. _________________ Photo's at http://shultzy.fotopic.net/
Workshop Here
Workbench Here
RouterTable Here |
| Back to top |
Chems Master Cabinetmaker
Joined: 23 Apr 2008 Posts: 2563 Location: Northampton
| Posted: Wed Mar 03, 2010 12:11 am Post subject: |
| OPJ wrote: |
Tom, I seem to spend more time working with sheet materials than any timber at the minute. |
I see no evidence of this on your blog! I hate to think your making things and not sharing it with us! |
| Back to top |
devonwoody Master Cabinetmaker
Joined: 11 Apr 2004 Posts: 8044 Location: Paignton Devon
| Posted: Wed Mar 03, 2010 8:38 am Post subject: |
| Sheet materials stored near an outside up and over door? woooooooooooooooe.. Mine is draughty and would let any damp air creep in and sheets dont like that. |
| Back to top |
| Posted: Wed Mar 03, 2010 10:29 am Post subject: |
| devonwoody wrote: | | Sheet materials stored near an outside up and over door? woooooooooooooooe.. Mine is draughty and would let any damp air creep in and sheets dont like that. |
Ah, but you see, I've made some attempts to draught-proof mine, which does make a difference. Still, this was my main source of ventilation before, which has now left me with a regular condensation and rust problem - must also install a couple of vents, fairly soon!
| Chems wrote: | | I see no evidence of this on your blog! I hate to think your making things and not sharing it with us! |
Don't worry. It's not too exciting, I'm just struggling to get things done at the minute; I keep jumping from one job to the other. I'll have updates when I'm done and ready. Should have some proper furniture to make soon though!  _________________ Olly.
Flickr Photos
| Back to top |
matt Master Cabinetmaker
Joined: 04 Sep 2005 Posts: 2191 Location: Miles away - totally impractical...
| Posted: Wed Mar 03, 2010 10:44 am Post subject: |
This is similar to my sheet storage, although I have an upright 2x1 in front that can be swung out of the way. It serves two purposes - something to flip the sheets forward on to so I can get at the one I want, and also to stop the sheets simply falling forward by accident.
One other thought, albeit a very minor consideration but one worth factoring in to the planning stage. Make sure the height of the plinth is no more than the difference between 1220mm and your armpit! It helps when it comes to getting the end of the board on to the plinth before sliding it home! |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
