| Author |
Message |
matthewwh Furniture Maker
Joined: 05 Jul 2006 Posts: 589 Location: North Oxfordshire
| Posted: Sat Feb 06, 2010 2:34 pm Post subject: |
Yep, it's the same yukka plant handles with the mahogany laquer stripped off.
Personally I prefer the au-naturel grasstree to the laquered finish, I might have a word with them next week and see if they can skip the laquer for us or replace it with something clear. _________________ Cheers,
Matthew
My new blog: http://workshopheaven.blogspot.com |
| Back to top |
Modernist Furniture Maker
| Posted: Sat Feb 06, 2010 9:02 pm Post subject: |
I think you're right. You could be excused for even thinking it looked a bit like cherry
Honed up the No 6 this afternoon and it is excellent. _________________ A cabinet of planes is never full
cheers
Brian |
| Back to top |
Trizza Woodworker
| Posted: Sun Feb 07, 2010 11:33 am Post subject: |
Definitely - those handles look much nicer  |
| Back to top |
Alf Hand Tool Goddess
Joined: 22 Oct 2003 Posts: 10937 Location: Up the proverbial creek
| Posted: Sun Feb 07, 2010 3:13 pm Post subject: |
Crumbs. Does look a bit nekkid... But there is grain under there. Hmm, I may be moved to have a go at mine now, but possibly refinish with a less muddy stain. Not too keen on pale handles for some reason. Thanks, Matthew. _________________ Regularly Musing from the Workbench again: Das Blog |
| Back to top |
turnerbc Forum Newbie
| Posted: Thu Feb 18, 2010 6:22 pm Post subject: Cheap Planes |
Hi all,
I have just made a big mistake and bought a Dakota No3 from Rutlands. Seemed a bargain - £20 off. Looked at Workshop Heaven's chinese planes and at Wood River planes and Toolmans . Comparing photos they looked virtually identical. My No3 Dakota is on its way back to Rutlands one hour after taking the plane apart. I found the frog was 1.5mm offset to one side as the threaded holes in the bed had been drilled 'off centre'. The frog had then been mounted at an angle and the blade and cap iron ground out of square so that it looked as though the blade was central to the throat. Might have to bite the bullet and buy a Clifton no3 unless any Mathew can reasure me about Workshop Heaven's chinese no3 ?
Regards,
Barry |
| Back to top |
pedder Furniture Maker
| Posted: Thu Feb 18, 2010 7:12 pm Post subject: Re: Cheap Planes |
| turnerbc wrote: | Hi all,
Regards,
Barry |
I think there is a reason why some retailer are later than others with these chiniese planes. They did their home work at the incoming goods inspection.
Cheers Pedder _________________ Visit my blog  |
| Back to top |
| Posted: Thu Feb 18, 2010 7:15 pm Post subject: |
Sounds horrible, Barry. Dunno if this might help with the Workshop Heaven #3. And Chris' (waterhead37) thoughts on the Clifton #3 too.
Cheers, Alf _________________ Regularly Musing from the Workbench again: Das Blog |
| Back to top |
| Posted: Thu Feb 18, 2010 9:24 pm Post subject: Cheap Planes |
Thanks for the links Alf. Its given me food for thought. I may well save up for a Clifton No3.
Regards,
Barry. |
| Back to top |
Paul Chapman Master Cabinetmaker
Joined: 26 Jan 2006 Posts: 6543 Location: Bookham, Surrey
| Posted: Thu Feb 18, 2010 9:53 pm Post subject: Re: Cheap Planes |
| turnerbc wrote: | I may well save up for a Clifton No3.
You won't regret it - the Clifton #3 is a fabulous plane.
Paul |
| Back to top |
Aled Dafis Furniture Maker
Joined: 29 Sep 2005 Posts: 688 Location: New Quay, West Wales
| Posted: Thu Feb 18, 2010 11:44 pm Post subject: Re: Cheap Planes |
| Paul Chapman wrote: | | turnerbc wrote: | I may well save up for a Clifton No3.
Paul |
Ditto.
Definately one of my favourites (along with the #5 1/2 and the #7)
Aled |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
