| Author |
Message |
wizer Professional Mutterer
Joined: 03 Mar 2005 Posts: 13670 Location: Creating and Fixing C*ckups Nr Dartford, Kent.
| Back to top |
Shultzy Cabinetmaker
Joined: 10 Oct 2006 Posts: 1617 Location: Near Lichfield, Staffordshire
| Posted: Mon Feb 08, 2010 11:59 pm Post subject: |
Too low for me Wizer, my workbench is 39" already . I have back problems and this height doesn't give me any gip. _________________ Photo's at http://shultzy.fotopic.net/
Workshop Here
Workbench Here
RouterTable Here |
| Back to top |
George_N Master Furnituremaker
| Posted: Tue Feb 09, 2010 12:22 am Post subject: |
I'm reading Chris Schwartz's workbench book at the moment. In the book he proposes 34" as the optimum height for hand tool work (I think he's 6'3"), the reasoning being, that you can get your full weight bearing down when planing, which you wouldn't be able to do if your arms are bent significantly. He goes on to say that if you mainly use wooden planes, the bench should be 31" high because the plane bodies are around 3" deep. It looks from the blog like he has had a bit of a re-think. I guess that those heights may be fine if you prepare all your stock from rough sawn by hand but a 31" high bench would have me bent double. _________________ cheers
George |
| Back to top |
Chems Cabinetmaker
Joined: 23 Apr 2008 Posts: 1674 Location: Northampton
| Posted: Tue Feb 09, 2010 12:26 am Post subject: |
| My saw bench is 33 inchs and this is the first surface I've had which I can plan on. My main bench was built before I got into woodworking and is pretty high, talking 45inch at a guess. Its great for hand routing and bits but can't do any planning as my arms get worn out as they are above heart level. But that once is coming out over the coming weeks to be replaced by a Robou so one of these would be ideal. So ideal actually I may just start one tomorrow! |
| Back to top |
ondablade Furniture Maker
| Posted: Tue Feb 09, 2010 1:51 am Post subject: |
I guess height for planing, versus height for chisel work is the question - how to accommodate what are essentially separate requirements.
Two possible disadvantages of this approach that strike me are that they seem likely to (a) result in lighter individual benches that are more likely to move about in use, and (b) to entail some walking backwards and forwards between benches _________________ Late starter.... |
| Back to top |
houtslager Furniture Maker
Joined: 16 Nov 2002 Posts: 738 Location: Oost Friesland / Chipping Norton
| Posted: Tue Feb 09, 2010 5:58 am Post subject: |
you could always make a secondary bench to sit on top of your "planing" bench to allow you to do chisel work or detsil work. This generally was a simple open box about 10" high
hth
hs _________________ you name it,I'll butcher it |
| Back to top |
waterhead37 Moderator
Joined: 14 Jan 2004 Posts: 6503 Location: SE London - NW Kent
| Posted: Tue Feb 09, 2010 7:30 am Post subject: |
| houtslager wrote: | you could always make a secondary bench to sit on top of your "planing" bench to allow you to do chisel work or detsil work. This generally was a simple open box about 10" high
hth
hs |
As has been extensively discussed here in the past with several members having made one.. _________________ Chris |
| Back to top |
Steve Maskery Master Cabinetmaker
| Posted: Tue Feb 09, 2010 9:07 am Post subject: |
He says:
| Quote: | | I can minimize my suffering ... by using a wider stance when sawing. Placing your feet farther apart lowers your torso, so you don't have to bend as much. |
Crikey, I haven't done the math (sic) but just how far apart does he stand to make any significant drop in COG of his body?
S _________________ Please form an orderly queue for my new (OK, no longer brand new but still pretty darned good) Bandsaw DVDs!
YouTube trailer here! |
| Back to top |
Harbo Cabinetmaker
| Posted: Tue Feb 09, 2010 12:21 pm Post subject: |
I have had a similar device for years - made from one of the original wooden topped Workmates
Not as sophisticated, but fitted with two Record Holdfast sockets and it folds for storage. I can even fasten my small portable Record metal vice on it too and the feet can be adjusted for uneven surfaces.
Rod  |
| Back to top |
| Posted: Tue Feb 09, 2010 2:52 pm Post subject: |
| waterhead37 wrote: | | houtslager wrote: | you could always make a secondary bench to sit on top of your "planing" bench to allow you to do chisel work or detsil work. This generally was a simple open box about 10" high
hth
hs |
As has been extensively discussed here in the past with several members having made one.. |
Including myself. I actually made my bench to just under elbow height (I'm 6'2"). So I got rid of the Benchtop Bench. I've no intention of ever doing extensive planing, so the 'joinery bench' is my standard every day bench. Just thought it was an interesting idea for those who do use standard height workbenches. _________________ **UK Workshop Forum Badge? Now taking orders, get one before they run out!**
“Success is not final, failure is not fatal: it is the courage to continue that counts.” |
| Back to top |
Benchwayze Master Cabinetmaker
Joined: 10 Mar 2007 Posts: 2433 Location: In Birmingham, wishing I had an 'olde-worlde' address more befitting a furnituremaker
| Posted: Tue Feb 09, 2010 3:49 pm Post subject: |
That's a Workmate on steroids!
Nice and neat for sure!
Thinking about it... One could always make a 'supplementary' benchtop. Two full length runners underneath. One runner gripped in the vice and the other, resting on the bench. The runners would need to be diffferent depths is all.
Or is that crazy?
John  _________________ "An engineer is a man who can make something for five bob that any fool can make for a quid!" Anon. |
| Back to top |
Mr Ed Cabinetmaker
| Posted: Tue Feb 09, 2010 5:50 pm Post subject: |
I am quite taken with the idea of this, having said that I don't really ever have an issue with using my normal bench for joinery. I mustn't once again fall into the trap of allowing shop improvements to distract from real projects though!
Ed _________________ Follow my blog at
http://thingswemake.wordpress.com/ |
| Back to top |
Chems Cabinetmaker
| Posted: Tue Feb 09, 2010 6:07 pm Post subject: |
| There is a fine balance thou ed, having the right area to work in improves the enjoyment of working 10 fold for me. |
| Back to top |
Mr Ed Cabinetmaker
| Posted: Tue Feb 09, 2010 6:27 pm Post subject: |
| Chems wrote: | | There is a fine balance thou ed, having the right area to work in improves the enjoyment of working 10 fold for me. |
I agree, I could quite happily spend ALL my time improving the workshop and tinkering about with things. I need reminders to start projects, because when I get one started I remember that this is what I actually enjoy.
| Back to top |
Chems Cabinetmaker
| Posted: Tue Feb 09, 2010 7:24 pm Post subject: |
I find that I spend much more time making projects then they go off to their owners and I have no physical reward for my work, but with workshop improvements I get to use it everyday  |
| Back to top |
