| Author |
Message |
Niki Furniture Maker
| Posted: Sun Feb 24, 2008 10:12 am Post subject: Table saw blade alignment - Lo-tech / Hi-tach |
Good day
Well, it's almost spring and I started to "warm-up" the machines..well, table saw and router table..that's all my "machines"
A few days ago I re-aligned the table saw blade, fence and sleds.
I don't have all this expensive equipment to align the blade to the miter slot so, I used a "Lo-tech" method just to bring the blade as parallel as I can, to the miter slot. I call it "Static alignment"
In my opinion, all the "Hi-tech" (and Hi-price) instruments can be "super-duper" accurate but, I think that the blade itself "knows" the best if it is aligned to the miter slot or not.
I call this check, "Dynamic alignment"...I just clamp a strip to the sled (or the miter gauge) and cut...when the strip reaches the back teeth, I listen to the noise...
If it's "cutting" noise, I know that I have to turn the blade clockwise.
If I don't here any noise, I know that I have to turn the blade counter-clockwise.
If I hear a "scratching" noise (I mean, the back teeth are just touching the strip) I know that the alignment is good.
Later, I check the fence alignment to the miter slot (Static check), rip some thin board and listen to the noise of the back teeth (Dynamic check)....and, same as above...
And as I know that, somebody will tell me "A post without pics is not a post".....(at least, not niki's post)...here are the piccies...
Regards
niki
And here is the "Dynamic test"
Listen to the noise of the back teeth
Bring the rip fence close to the miter slot and check the distances at one end...
....And the other end
Cut a test piece and listen to the back teeth noise...
I do the same also on the long fence
To check the squareness of the sled, I took a piece of thin board (floor panel)....
And cut it to 4 pieces
I alternate the pieces and checked them on a straight edge...any mistake will multiply itself...
| Back to top |
Woodmagnet Cabinetmaker
| Posted: Sun Feb 24, 2008 2:23 pm Post subject: |
Another good one, many thanks Niki.  _________________ People forget how fast you did a job - but they remember how well you did it.
I'm a Woodmagnet.
A.K.A. Kevin. |
| Back to top |
Newbie_Neil FA Cup Finalist 08/Play-off Finalist 10
Joined: 27 Jul 2003 Posts: 5632 Location: Nottingham, England
| Posted: Mon Feb 25, 2008 8:11 am Post subject: |
Hi Niki
Thank you for another of your excellent tips. The time you give is really appreciated.
Cheers,
Neil _________________ Tool Store Heaven and Woodworking Shows |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
