Mistake of the week...
NazNomad
30 Aug 2015
After laminating a lovely oak-beech-oak blank and spending ages carefully cutting it on the bandsaw this morning, I realise the template was reversed.
I'm now the proud owner of a very nice left-handed banjo neck blank....
That should fetch a premium, can't be many Banjos made specifically to cater for a sinister player.
John Brown":yuc8ow5m said:
I take it it's a five string?
Unfortunately.
I'm so disappointed with myself that I can't muster the enthusiasm to go out and glue up another blank...
I don't get it... Can't you just turn a banjo upside down, reverse the string order and play it lefty? :p
Probably more than you'd think...
http://leftyfretz.com/buy-left-handed-banjo/
Left-handed piano, however... that's far scarcer!! :D
Not with a 5 string, it has a step in the neck.
I ''may'' have gotten around it.
I ripped off the step to make it a 4-stringer, then glued a long thin wedge on the correct side to create the step where it should be.
I also cut a new neck from a solid oak blank, so if the fist bodge doesn't work I'll not be without a neck. It's for personal use anyway, so as long as it works...
What a c0ckw0mble. :-D
Too flippin' cold and wet outside now, the rest of the day is devoted to coffee and Skyrim.
Q: What does a correctly tuned banjo sound like?
A: Nobody knows.
Now I can't get the name 'Billybob Hendrix' out of my head.
I write left-handed, I'm ambidextrous with a hammer and saw, throwing and most everything else is right-handed.
Anyhoooo, the f-up that started this thread has actually turned out pretty nice. You can hardly see the join and the home-made drawknife worked like a dream.
banjo player: "When I die, I want to leave the world a better place."
guitar player: "Don't worry, you will."
