Blade facing wrong way?
SuzyJones
Member
28 Nov 2017
Bonnyrigg, Midlothian
Hi, I'm totally new to scrolling but having taken my work pension a couple of weeks ago, I fancied having a go. I was going to buy an inexpensive Scheppach scroll saw but Aldi had a similar one for about half the price. My husband set it up and it seems to work well (in as far as I know), however the pinned blade cutting edge faces to the left which means I have to stand to the left to cut. This doesn't seem right to me but what do I know? Is that normal?
In the meantime I'm waiting for some pinless blades I bought on the internet to try some internal cuts. Looking at the instructions, these would be facing the front, so looking forward to trying those.
Thanks for any advice.
Cutting edge usually faces forward, is there an adjustment or rotating mechanism? Or maybe the blade holder not seated correctly Photo would help.
EDIT: Just looked at the saw on line and whilst the photo isn't clear it does show the blade cutting edge to the left so I don't know. Not sure it makes any difference when you're working though I'd find it a bit strange at first.
Is this it? https://www.aldi.co.uk/workzone-120w-sc ... 0173517100
Bob
Morning, your blade should be facing front usually
Do you have a picture of the blade clamp/holder on yours
Does yours look similar to this ?
I wonder if you have this type of blade holder?
Which allows side fitting of a pinned blade and well as forward facing ?
Most are just forward facing
The ADLI (Workzone) saw is the generic saw that is sold by everyone and their granny (Record, SiP, Scheppach, Jet, Ozito, Kobe, Clarke, Dayton, Ryobi... the list is almost endless)
As above, the pinned blades should be able to face in any direction, which is often useful if your workpiece is larger than the throat of the saw.
Whilst they are largely the same basic machine, they do have a few differences seller to seller, one being the blade holder, not all have the facility of side blade fitting
Oddly I have yet to find a manual for a machine that fully explains it even when it has that side fitting type fitted
Yes this looks a bit like it (second picture). So relieved it's not a dud. (Well it does cut I suppose..)
Thanks.
Bob
Thanks for the video link, I hadn't seen that. It shows the man cutting a bit of wood from the left, so should be alright.
.. then he angles the table and still cuts from the left, proving that he's an actor and has no fekkin' idea what he's doing. :-D
It should do *both* forward facing and sideways with the same blade holder
Using pinless it will only take the pinless adapter cutting forwards as you look at the saw
The pinless adapters with this type of blade holder are a bit of a pain I will warn you, so don't be put off by them being a bit fiddly to use
Other saws have different types of blade clamp and are much better/easier to use
You will learn over time
Enjoy it
Thanks.
Would a cheapo scroll saw like that do for 10mm thick hardwood? Just occasional use - I've got a windsor chair splat to do.
If it does cut from the left what happens when he tilts the table? He will not be getting angled cuts or the angled cuts will go from front to back instead of left to right.
Its the users choice whether they use the blade at 90 degrees or straight
Its meant to enable longer cuts
Sorry my bad, I thought it was set like that I didn't realise it could be changed.
Which is precisely what the numpty does in the promotional video, see my earlier comment :-D
