guyos
Hello folks
I have built a box joint jig, but I am unable to get a joint that fits. I have been advised the number of cuts and turns to make but joints are too loose. I suspect that because my saw kerf is 1/8" and the rod an M10 (don't know the TPI) that could be the cause of the problem.
If I am right, is there a way to amalgamate the two by altering the turns & spins, or do I have to change the blade as I don't seem able to get a proper imperial 3/8 rod.
Your advice appreciated.
Guyos
Guyos
