Structural design issue
[email protected]
30 May 2017
London
Hi Ive been asked to make a floating shelf from 18mm plywood. If you can imaging 2 x 90 degree 's' shapes on top of each other with no supporting rod in the spaces, if that makes sense, so no supports for the overhangs. No back panel either.
Its being mounted on a plastered brick wall. No fixings can be seen. Floating is the plan.
Each shelf of the 4 shelves will be approx 300/300 the whole height is approx 950mm
Has anyone had any experience of making something like this who can pass on tips.
Many thanks
A sketch would help tbh
