flanajb
- Joined
- 11 Mar 2009
- Messages
- 1,313
- Reaction score
- 11
We have maple worktops and the last time I resealed them I used a Sadolin water based laquer. Now I know that this is most likely not food safe, but as we always use chopping boards for food prep nothing really came into contact. I have subsequently had to scrape the finish off as it became very tacky to the touch and if you put a cereal box onto the surface it would stick so bad that the box would tear off and stay stuck to the surface :-O I blame the wife as I suspect it is the constant use of dettol anti bacterial sprays that have caused the surface to do this. The area under the microwave was not sticky.
I digress, but what I want to try and understand is whether I can use water based laquer or would people strongly advise against this?
I don't want to go down the oil route for the following reasons.
1. It stinks.
2. Can only apply one coat every 24 hours
3. We are too lazy and will not apply additional coats 2-3 times / year
4. Not convinced oil is that great anyway.
So is there a magic sealer or can I use the water based again.
1. It stinks.
