Help with a project
stu5
New member
29 Apr 2016
Bucks
hi guys
this is my first time on this site , I have a project in mind , I have a McKellar 10" table saw which my dad gave me and the table is not bigger enough and the fence is not good either, I would like to modify this so I could cut bigger sheets? has anyone modified one of these before? any ideas .
thanks for your time , all the best stu
Take a look at ibuildit on YouTube. John Heisz has recently done a video on making a fence from wood that's better than the original.
However, cutting large sheet goods is often a lot easier with a circular / track saw unless you have room for decent in feed and out feed extensions
I concur with mattroberts. I have a table saw with 620mm ripping width but I find it much easier to use my plunge saw for cutting down the sheets. Or speak with your timber merchant, sometimes they will cut them down to rough sizes for you.
Cutting big sheets is never easy on a table saw especially if you are on your own. They can be pretty hard to control.
If you can get hold of a plunge saw or make a rail to go with a circular saw you will probably get on easier.
