deema
I'm looking into either getting a Panel saw or a Wall saw, and can't work out which is the best. My research indicates that a wall saw has many advantages over a panel saw, however, it seems that wall saws are no longer that popular with most people I know having a space hungry panel saw.
The advantages of a wall seem seem to be
1. I can load it easier, I'm predominantly on my own so lifting 18mm sheets onto a flat table isn't something I enjoy on my own. However getting them on a wall saw is easy.
2. Wall saws can have scribing blades and can also plunge which a panel saw can't.
3. They can cut angles as well as straight cuts.
4. They use up less floor space.
5. The only disadvantage I can find is that I haven't found one that can cut a bevel.
6.The wall saw does need the battens replacing once in a while.
I've convinced myself that I must not be looking at this correctly and have missed out on some key advantage of the panel saw. Your views and recommendations would be appreciated.
