UKWorkshop Woodworking Forums
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2  Next
Author Message
PostPosted: 14 Jul 2009, 13:47
Offline
Settled in Member
Has thanked: 1 time
Been thanked: 8 times
Your opinions please. I have a chance to buy a NuTool BT130 that has never been used. It's a year old.
I am currently doing a job that requires planing/squaring up of some 4"x4" legs, possibly gonna be oak. Is this up to it? Spec claims it'll take max thickness of 130mm so it should be ok.
anyone any experience of NuTool stuff?
_________________
simple woodworking sum...
4 jaw lathe chuck + 2000rpm + bare knuckles = loud swearing
Share on Facebook Share on Twitter Share on Digg
 Profile
 Post subject:
PostPosted: 14 Jul 2009, 14:30
Offline
Valued Contributor
Has thanked: 0 time
Been thanked: 7 times
Like most things - buy cheap, buy twice (at least). Having said that - I suspect more people buy and upgrade over time than those who buy the final item first time round - if you follow. If you work on that assumption, then people do start at at different points.
I remember getting one of those a long time ago - it went back 2 days later. I suppose if you are willing to hand-finish the items then it could do most of the work for you. Best to try it.
However having looked a picture of it - you still need a jointer (I think that's what the 'muricans call it).
 Profile
 Post subject:
PostPosted: 14 Jul 2009, 14:41
Offline
Valued Contributor
Has thanked: 139 times
Been thanked: 164 times
I've got one of those which someone here kindly gave me.
Its OK for rough Prep & sizing - I prefer to hand plane finish.
Bit of a screamer
Seems quite solid
They were not much more than £120 when new I believe
If I were buying I doubt I'd pay over £45 for it.
 Profile
 Post subject:
PostPosted: 14 Jul 2009, 14:44
Offline
Settled in Member
Has thanked: 1 time
thanks guys, guy wants nearly £100 for it - might just pass on it and put the money towards a more substantial one.
_________________
 Profile
 Post subject:
PostPosted: 14 Jul 2009, 14:49
Offline
Valued Contributor
Lee J wrote:
, guy wants nearly £100 for it -.
I wouldn't contaminate a barge pole at that price.
 Profile
 Post subject:
PostPosted: 14 Jul 2009, 15:17
Offline
Settled in Member
Has thanked: 1 time
I dont mind finishing by hand, I wouldn't expect it to give me a finish of high standard, I just need it to square up some stock
_________________
 Profile
 Post subject:
PostPosted: 14 Jul 2009, 15:59
Offline
Settled in Member
Has thanked: 0 time
Been thanked: 4 times
Lee, what it won't do is square up stock. It's only a thicknesser, so you will need two adjacent faces flat and square to each other before it's of any use to you.
It really annoys me that so many sellers of these things insist on calling them Planer Thicknessers, 'cos that's a misleading description.
Rant :evil:
 Profile
 Post subject:
PostPosted: 14 Jul 2009, 17:24
Offline
Settled in Member
User avatar
Has thanked: 0 time
Been thanked: 0 time
I recently bought the MacAllister thicknesser from B&Q for £180-ish. Have to say I was very impressed with it.
I spent a day planning up some oak and Iroko planks that I'd salvaged from pallets. The finish was very good with only a light bit of sanding required.
As has been said - a thicknesser wont give you square timber - just parallel.
hth.
Bryn :D
_________________
Cheers.
Bryn :-D
 Profile
 Post subject:
PostPosted: 14 Jul 2009, 20:26
Offline
Settling In
User avatar
Has thanked: 0 time
hth.
Bryn :D
Ah! Wish I hadn't just read that! I was looking at those when I was in the market to replace my SIP 13". I just couldn't convince myself that one of B&Q's house brands was the way to go. I ended up with the Fox entry level model.
_________________
When you need a machine that causes something very sharp to turn several thousand RPM - - DON'T BUY THE HOUSE BRAND!
 Profile
 Post subject:
PostPosted: 14 Jul 2009, 21:26
Offline
New Recruit
Has thanked: 0 time
i have used a mac thicknesser for the last six months i think its great for the money would buy another one if i had to
 Profile
 Post subject:
PostPosted: 14 Jul 2009, 21:48
Offline
Settled in Member
Has thanked: 0 time
Of course if you're prepared to put in the effort, it is possible to make a sled to hold the stock in the right position to use the thing as a Planer, but for one job?
It is also possible to use a Planer to get the stock square then get the thickness by doing repetitive cuts on the same machine until you get what you want.
In my opinion, if what you want a machine for is for frequent squaring this would be the way to go and then consider the Thicknesser or a P/T as a future purchase.
 Profile
 Post subject:
PostPosted: 14 Jul 2009, 21:59
Offline
Settling In
Has thanked: 0 time
A while back 2 or 3 years ago, I bought a Nu-Tool bench top planer , it worked reasonable but very noisy, 2 years ago on ebay I bought a brand new Nu-Tool lathe with electronic speed control , I have given it a fair bit of use and cannot fault it.
IMHO some of the Nu-Tool stuff is not bad
_________________
Denny
 Profile
 Post subject:
PostPosted: 14 Jul 2009, 22:09
Offline
Settled in Member
Has thanked: 1 time
derrrr spot the newbie to wood working :oops:
of course a thicknesser isn't gonna square stock up unless there is a square side to start from. :oops:
Well i didnt bother with it anyway, I will invest in a P/T within the month but for this 1 off job I'll manange by hand.
I have a MAC router and it's great, I too was skepticle about MAC but it's been a good router.
_________________
 Profile
PostPosted: 15 Jul 2009, 09:26
Offline
Settling In
User avatar
Has thanked: 0 time
There's info (well, a bit) here
http://www.reviewbuzz.co.uk/DIY-Gardeni ... views.aspx
For the sake of accuracy I think we should all agree on terms. As far as I'm concerned, this is a thicknesser
http://www.amazon.co.uk/Dewalt-Dw733-Po ... B0001IWFIQ
This is a planer
http://www.amazon.co.uk/Silverline-Hi-S ... 86&sr=1-22
And this is a planer/thicknesser
http://www.machinemart.co.uk/shop/produ ... icknessers
_________________
 Profile
PostPosted: 15 Jul 2009, 11:54
Offline
A Regular Member
User avatar
Has thanked: 0 time
FogggyTown wrote:
Ye gods! Only £126 for a planer, is it any good at that price?
_________________
If at first you don't succeed, get a bigger hammer!
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: Techy1954 and 7 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
 Similar topics   Author   Replies   Views   Last post
Planer thicknesser
in Jigs, Tips & Shopmade Tools
Peter D
3
672
21 Dec 2016, 17:55
Planer thicknesser
in For Sale
Mar_mite
1
676
12 Feb 2017, 17:10
Planer thicknesser
in Buying Advice | Tool Reviews
Bolman
18
1257
27 Aug 2016, 18:01
planer thicknesser
in General Woodworking
ivor
9
1211
08 Apr 2016, 18:18
Fox planer thicknesser
in For Sale
CS Bespoke Furniture
4
328
20 Feb 2017, 01:43
Register UKW
User Tools
UKW Local
Quickly find the nearest tool suppliers & timber merchants in your area
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
UKW Terms & Privacy
phpBB SEO
