| View previous topic :: View next topic |
| Author |
Message |
LocalOak Woodworker
Joined: 20 Nov 2007 Posts: 191 Location: Herefordshire
| Posted: Sat Mar 13, 2010 8:31 pm Post subject: |
"Or a wind-up? "
Note to self, don't post too late at night...  |
| Back to top |
johnjin Furniture Maker
Joined: 11 Nov 2003 Posts: 597 Location: Whaplode Lincolnshire
| Posted: Sun Mar 14, 2010 9:17 am Post subject: |
Just for information.
A diamond file will cut the hardened metal and it will also cut Carbide.
John |
| Back to top |
bugbear Master Cabinetmaker
Joined: 16 Jul 2004 Posts: 3899 Location: North Suffolk
| Posted: Mon Mar 15, 2010 10:03 am Post subject: |
| CroppyBoy1798 wrote: |
Well I've spent the last 5 hours or so stooped over the blade cutting new teeth! (Wish it was as easy to make new teeth for myself!! ). 8 teeth per inch on a 26" long blade........you do the maths! . Leveled the teeth, then trimmed then before setting the teeth. Hopefully I'll get the final sharpening done tomorrow, the tough bit, with the angles and all |
It's a little late, but some good advice from Mike Wenzloff when cutting new teeth is to use a larger, coarser file for the early stages.
Makes the job go a little faster, and saves some wear on yourgood sharpening files.
Also too late... a saw with no teeth is at a VERY good stage for any blade cleaning or polishing you had in mind - the tooth (especially if they have significant set) make cleaning the edge very fiddly.
BugBear _________________ Grinding, sharpening and polishing are really very interesting operations.
...William Henry Bragg |
| Back to top |
CroppyBoy1798 Woodworker
| Back to top |
| Posted: Thu Mar 18, 2010 10:07 am Post subject: |
How did you mark out the teeth for cutting?
| Back to top |
| Posted: Thu Mar 18, 2010 9:29 pm Post subject: |
| bugbear I measured it out off an inch ruler, using ever eight to mark the point of each tooth (8tpi). I just put a little tick then on the flat of the fresh cut. Then filed in between everyone of these points until the new V cut reached the tick on either side. Holding the file at approx the same angle it took between 20-24 strokes to cut each tooth. |
| Back to top |
| Posted: Fri Mar 19, 2010 10:55 am Post subject: |
| CroppyBoy1798 wrote: | | bugbear I measured it out off an inch ruler, using ever eight to mark the point of each tooth (8tpi). |
Ouch.
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
UK, tools, machinery, woodworking, DIY, wood, drills, saws, power tools, second hand machinery, table saw
