UKWorkshop Woodworking Forums
Post new topic Reply to topic  [ 5 posts ]
Author Message
PostPosted: 06 May 2008, 21:37
Offline
New Recruit
Has thanked: 0 time
Been thanked: 0 time
Hi I'm missing the above for an old Cooksley planer thicknesser and have to make one.
I've made a few passes without it and was so scared I nearly slipped in my own pee.
Anyone had experience/design ideas here for same to save me reinventing the round thing?
Share on Facebook Share on Twitter Share on Digg
 Profile
 Post subject: Re The above
PostPosted: 06 May 2008, 21:41
Offline
New Recruit
Has thanked: 0 time
by the way, I was thinking of a spring action wedged/triangular shaped guard rather than just a flat, static cover.
Ta
 Profile
 Post subject:
PostPosted: 06 May 2008, 22:29
Offline
Valued Contributor
Has thanked: 0 time
Been thanked: 5 times
Yes. I've replaced several. Personally I'd avoid the sprung designs so popular in the USA. They make for extra resistance when passing work across and always seem to leave a lot more of the blade exposed than the British-pattern bridge guard (not crown guard, BTW). The design of guard for your machine can be clearly seen in this picture (from D.B.Keighley's web site):
I just feel more at home with a guard which can be set-up to cover the blade at all times when surfacing, despite a slightly tricker feeding action to master (which takes all of 10 minutes). Your machine appears to have the casting to hold the guard post, so you may well be part way there already. There's also the fact that if you are trade the American-style swing-away guard is not legal here, so your insurers won't like it, either. The best design I've ever used is the SUVAMatic guard:
but they are really expensive but probably the safest design around. Next best option is probably the parallel arm bridge guard supplied on many modern European machines:
Neither of these are cheap, but they are better designs than the traditional bridge guard and it may well be possible to engineer the parallel arm type yourself.
Incidentally your machine is a Whitehead, not a Cooksley. See here for details (and a bit about the Wadkin BRT)
Scrit
_________________
Customer Feedback (no stamp required) Have you found this post helpful? Please tick the appropriate box, tear along the dotted line and return to Woodwork UK:
 Profile
 Post subject:
PostPosted: 07 May 2008, 00:07
Offline
Settled in Member
Has thanked: 0 time
Cant help with the machine info, but the man that could/can already has...
Nice to see a knowedgable face again ,Scrit :D
_________________
Neil.
If its true and we learn from our mistakes... I must be a genius.
 Profile
 Post subject:
PostPosted: 07 May 2008, 06:14
Offline
Valued Contributor
User avatar
Has thanked: 0 time
Been thanked: 48 times
Yes i would agree with Scrit on this one,even though i did always like the look of the spring loaded guard/cover,but now after using one,albeit only on the Fox 6" joiner,i would now rather use the bridge guard.
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: Chrispy, RobO and 7 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
 Similar topics   Author   Replies   Views   Last post
Fox planer thicknesser
in For Sale
CS Bespoke Furniture
4
527
20 Feb 2017, 01:43
Planer thicknesser
in Buying Advice | Tool Reviews
Bolman
18
1363
27 Aug 2016, 18:01
Planer thicknesser
in For Sale
Mar_mite
1
786
12 Feb 2017, 17:10
Planer thicknesser
in General Woodworking
Jezzza55
7
339
05 Feb 2017, 09:29
planer thicknesser
ivor
9
1264
08 Apr 2016, 18:18
Register UKW
User Tools
UKW Local
Quickly find the nearest tool suppliers & timber merchants in your area
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
UKW Terms & Privacy
phpBB SEO
