Andy Pullen
After recently using a Festo saw and guide at work I must admit I was quite taken with the way the guide had rubber strips stuck to the underside so it could be used without clamps, really neat idea. Messing about in my workshop later with some homemade guides made of mdf with a batten routed down the center i was wondering what i could use for the same effect and rummaging around i came across some self adhesive foam tape that is sold by Carroll tools for their range of drum sanders. it is 75mm wide so I split it into 3 strips and fixed it to the underside of the guides. Crikey it really grips, immovable in fact yet you can just pick it up and move it. It costs £1.50 a metre and obviously you can make your guides to suit whatever without any massive outlay.
Just thought someone else might like to use the idea. Regards Andy
