Page 1 of 1
[ 5 posts ] |
| Author |
Message |
PeterK
Posted: 20 Mar 2009, 16:46 |
| Forum Newbie |
Joined: 23 Feb 2008, 17:43 Posts: 1 Location: Leigh-on-Sea, Essex Has thanked: 0 time Been thanked: 0 time
I've bought a second-hand Record Coronet CL3 (36 inch blue) which came with a Record Collet Chuck set. But I also got two large 3.5 inch dia chuck bodies with a total of 3 sets of 4 quadrants in grey caste metal of different diameters. When placed in the body they create a conical shape. There are no maker's markings on any of it. Record don't think they made them but they do seem to fit with other parts of the Record Collet Set. Any ideas?! I assume they would form a dovetail compression or expansion kit if I can get them in the right order!
Peter
| Top |
PowerTool
Posted: 20 Mar 2009, 17:11 |
| Valued Contributor |
Joined: 24 Jul 2005, 20:57 Posts: 3227 Location: Darlington Has thanked: 0 time Been thanked: 0 time
No idea,unfortunately,but welcome to the forum
Pictures would probably help,the spam trap will stop them until you've made three posts,though.
Andrew
_________________ HAMMER ACTION - when all else fails !
| Top |
TEP
Posted: 20 Mar 2009, 18:20 |
| A Regular Member |
Joined: 11 Mar 2007, 15:40 Posts: 1358 Location: Chester Has thanked: 0 time Been thanked: 0 time
Welcome to the forum Peter.
Ditto on the photos, a lot easier when we can see the bits. As Andrew said you'll have to get another couple of posts under your belt before you can post a outside link.
_________________ regards
Tam
| Top |
Bodrighy
Posted: 20 Mar 2009, 18:22 |
Joined: 06 Jan 2007, 01:51 Posts: 5203 Location: Bromham, Wiltshire Has thanked: 0 time Been thanked: 7 times
Blimey another Peter.  Welcome to slopeland. Some chucks don't apparently have to have the jaws in any set orsdwer I have been told by a Pro. Post a pic and there's a good chance that someone on here will have one or know about it.
_________________ Mistakes are serendipity in disguise
He who works with his hands is a labourer, he who works with his hands and his head is a craftsman, he who works with his hands, his head and his heart is an artist (St Francis of Assisi)
| Top |
dickm
Posted: 22 Mar 2009, 10:33 |
Joined: 25 Oct 2004, 18:35 Posts: 2719 Location: North of Aberdeen Has thanked: 13 times Been thanked: 23 times
Sounds like the Coronet 6-in-one chuck which is about that diameter. There should be a thing like a truncated cone with a parallel section at the base that fits into a recess in the centre of the chuck body and when the chuck is tightened, this expands the four jaws to grip in a recess on the work.
Mine's been in use for 25 years at least, and it's fine within its limitations. That is, only about 1/4inch movement on the jaws, and a need for three, or possibly four, hands when assembling it! The jaws are supposed to be held together with a rubber band, which always perishes and snaps. Worth making a thin spring wire clip to do the same job.
_________________ Dick M
| Top |
Page 1 of 1
[ 5 posts ] |
Who is online |
Users browsing this forum: No registered users and 2 guests |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
Quickly find the nearest tool suppliers & timber merchants in your area
