UKWorkshop Woodworking Forums
Post new topic Reply to topic  [ 11 posts ]
Author Message
PostPosted: 19 Oct 2008, 13:39
Offline
Settling In
Has thanked: 0 time
Been thanked: 0 time
Anyone any experience of these ?
http://www.axminster.co.uk/product-Axmi ... -21303.htm
I'd only be cutting a few threads so don't need lifetime quality.
Andrew
Share on Facebook Share on Twitter Share on Digg
 Profile
 Post subject:
PostPosted: 19 Oct 2008, 13:47
Offline
Settled in Member
Has thanked: 0 time
Over here on my side of the pond we use about the same thing only its called a Beall Wood thread Box about the same thing you have a picture of and it works quite well.I just wish I could find one that would do 2-3 " ones
_________________
Makin Sawdust
 Profile
 Post subject:
PostPosted: 19 Oct 2008, 13:49
Offline
Settling In
Has thanked: 0 time
Been thanked: 2 times
Bought one for my father a couple of years ago. He made me a pair of wooden clamps using them that work very nicely. He only uses it occasionally but is very pleased with it.
Mark
 Profile
 Post subject:
PostPosted: 19 Oct 2008, 13:54
Offline
Settling In
Has thanked: 0 time
It seems a good match for the price / occasional use so I might try one. Thanks for the inputs.
Andrew
 Profile
 Post subject:
PostPosted: 22 Oct 2008, 21:48
Offline
A Regular Member
User avatar
Has thanked: 2 times
Been thanked: 1 time
If you get it can you do a review? I'm thinking about one too, thanks
Aidan
_________________
That's not a mistake... it's a design feature!
 Profile
 Post subject:
PostPosted: 23 Oct 2008, 10:01
Offline
A Regular Member
User avatar
Has thanked: 19 times
Been thanked: 30 times
I have one and it works quite well. One limitation is on the male thread - you can't get a thread right down to a shoulder - if you see what I mean - there's quite a gap, as the shouldered part prevents all the tenon getting into the die cutting part.
_________________
Nick
>> A good friend will come and bail you out of jail, but a true friend will be sitting next to you saying, "Damn ... That was fun!" <<
 Profile
 Post subject:
PostPosted: 26 Oct 2008, 15:49
Offline
Settling In
Has thanked: 0 time
Works pretty well on the beech I'm trying it on right now, especially if you remember to oil it like the instructions say. The tap looks like it might last longer than the thread cutter but time will tell and at my expected work rate that should be many, many years.
Like Nick said you can't thread right down to a shoulder but for me that is not a problem.
I'm still all excited about my new bandsaw - for some reason my better half seems hugely unimpressed when I come running upstairs exclaiming "look, the skim I just cut off the face is so thin you can almost see through it". 6 yr old son is always duly impressed (which is why there is a lock on the power).
 Profile
 Post subject:
PostPosted: 29 Oct 2008, 10:17
Offline
Settled in Member
Has thanked: 4 times
Been thanked: 34 times
Apologies if Axminster has altered their design since I bought my set of thread boxes about 15 years ago, but there is an entry guide consisting of a wooden block on the face of the box that guides the dowel into the cutter box.
It’s held in place on the entry face of the screw box by a couple of screws and when removed, gives access to the vee cutter underneath.
In use, the cutter cuts the thread first and it is held in place and advanced at the correct rate by a metal thread behind that follows on the thread you have just cut.
I have successfully cut threads to within a gnat’s nibbler of a shoulder by starting the thread in the normal way until reaching the shoulder, where it stops. You then unscrew it, and remove this block to complete the last 3/4” or so.
In this way the cutter is able to travel right up to the shoulder. You will need to tidy up the ragged end of the thread with a small pointed knife.
For a nice finish, return it to the lathe if possible, and undercut a groove at the end of the thread beside the shoulder.
Whatever you do DON’T alter the Vee cutter’s position. They are a first class pig to get right if moved.
Hope this helps
 Profile
 Post subject:
PostPosted: 29 Oct 2008, 20:40
Offline
Settling In
Has thanked: 0 time
Yes they still make them the same way :)
 Profile
 Post subject:
PostPosted: 30 Oct 2008, 18:43
Offline
Settled in Member
There you go, Andrew. Threads all the way to the hilt. The secret is to cut all your threads as far as they will go before you unscrew the block, then thread it back on and complete the last few threads.
However, be careful with beech - it splits out on the threads like nothing else.
 Profile
 Post subject:
PostPosted: 30 Oct 2008, 20:16
Offline
Settled in Member
Has thanked: 0 time
I'll just add my experience. I bought one many years ago, used it once and then lost the tap. :oops:
I felt that the tap didn't cut a very good thread in the beech I was using, but I was going down the end grain.
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: Chris152 and 6 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
 Similar topics   Author   Replies   Views   Last post
Cutting guide fence for Axminster mitre saw advice sought
in Jigs, Tips & Shopmade Tools
devonwoody
3
565
17 May 2017, 07:32
cutting into engineered wood
in General Woodworking
thetyreman
6
486
05 Aug 2017, 17:17
Yet another "What wood is this?" Thread.
MJP
11
333
03 Jan 2018, 14:23
Another "what's my wood?" thread
sploo
24
823
03 Jul 2017, 23:48
Another bad day good day thread
in General Chat (Off-Topic)
Steve Maskery
13
674
11 May 2017, 21:51
Register UKW
User Tools
UKW Local
Quickly find the nearest tool suppliers & timber merchants in your area
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
UKW Terms & Privacy
